Mikeosaji
Can someone tell me which fuse is for my mad sensor I ran a code scan and it said Mass Air Flow signal is/was low or grounded so will I have to change my air flow sensor or is there something else I could do
Maybe use mass air sensor cleaner? Check all fuse with fuse tester? If not replace it
A sensor mentioned in a code definition usually means the sensor IS WORKING or it wouldn't have a low or high range, it would have NO RANGE/broken
So don't SHOOT THE MESSENGER when a code comes up, lol
that would be like replacing your fuel level sensor because the guage reads empty. Instead, you correct the problem that is causing the low fuel level - put fuel in the tank.
Move the nozzle and fill the other tank.And what do you do if you've added 20 gallons of fuel to the tank, and the gauge still reads "Empty"?
