Ford Granada rims
mc_muench
"Miller"waukee
I found some 14" cragers on CL and had a question, the ad says they're from a 1977 Ford Granada and 5 x 110mm? and I know that ranger rims are 5 x 114mm so I checked the tire fitment guide in the tech and it says they should fit, so maybe they guy selling just wrote it wrong, but there's an * after it but no add on, so my question is will they fit without any major mods?
ad
http://milwaukee.craigslist.org/for/1703295685.html
best thing to do, is take a measuring tape with you and measure the bolt holes as it says to do in the tech section, or take one(rim) and try it on your truck.
Robert
Same thing that I have on my 72 mustang.
They are 5 on 4.5 which is the same as the ranger
It should bolt up. I believe the center hole on the Granada wheels will be bigger than a 2wd ranger though.
Those are oblong bolt holes on the wheels that require a unilug type nut. They rarely ride real good.
Stay away from these.
Does that require somthing like these:
or these:
if the rims take those type of lugs, dont buy them, the center hole has to be right so the wheel won't wobble, I had a set of old slot mags once on a car that had the long holes and took those type of lugs and washers, rode like really bad, I could never get the wheel centered on the hub to not wobble
Robert
