Ford F150 9.75 installed on a 2000 Ranger
Quasi242
January 2010 OTOTM Winner
OTOTM Winner
Tucson, Arizona
For anyone looking for an upgrade to the more common Explorer 8.8 swap, here is another option. The F150 9.75 axle is approximately 7" wider than stock (the Explorer 8.8 is approximately 3" wider than stock). Dimensions use a 2000, 28-spline, Ranger 8.8 axle as reference. The F150 9.75 axle also offers 34-spline axle shafts and is roughly equivalent to a Dana 60.
I just finished the install on my 2003(?) Ford F150 9.75 axle swap. Everything went fairly simply and was as close to a plug and play solution as possible. For the Record, here are the items that were a direct match to my 28-spline 8.8 axle:
Drive shaft flange (identical)
Speed tone ring (same number of teeth)
Speed sensor (identical)
Width (I wanted full width axles for my prerunner)​
This axle has disk brakes with 13" rotors. I had new soft lines and hard lines made for the axle. The brakes seem to be working fine with the stock master cylinder. I had to replace my 15" wheels with 17" wheels to clear the rotors. 16" wheels may have fit but I decided to play it safe.
Things that required extra work:
I had the axles and rotors redrilled to 5 on 4.5 bolt pattern
Welded the axle tubes to the carrier (optional-but welded fine)
I had to shorten the stock drive 2-piece drive shaft
I moved the spring and shock mounts to work with the Ranger frame​
I am happy with the way that this axle swap worked out. I found it on Craig's List for $400.00 complete with factory posi, disk brakes, and 3.55 gears (I regeared the axle to 4:88). The truck seems to be happy with the axle as I have not had any issues with the 4-wheel ABS or other computer codes/errors. The only loose end, is reconnecting the e-brake. I am currently looking for a used set of cables.
Here are a couple of pictures (additional pictures are in my build thread in the prerunner forum):
wow, im a 4x4 guy but that truck makes me want a prerunner. I have the same axle under my f-150 with 4:10 and 35's and i beat on it and tow alot. no problems after 250,000kms. nice work!
Thanks. I am also a 4X4 guy, I just want it to go fast as well. This truck is actually a 4X4. When I can afford to regear the front differential, I will reinstall the front CV axles. Glad to hear that the 9.75 axle has performed well for you.
I may actually do this swap... Just did a brake job on my buddy's '03 F-150 and it featured 16'' wheels on top of the disc brakes. Very easy job.
This axle was found on the 5.4L 150's and the 4.6's with the optional tow package.
Also, this is how you use the search feature noobies.
