It's been awhile since I had posted anything so here goes.
I've been having cold start problems intermittently. when I start it up it will rev up to 1500 RPM for a second or to then it drops down to 500 then back up to 1500 and it will do that till it settles in at 1300. Then after about 30 seconds later the RPM will drop real low and it starts sputtering and missing real bad almost dying but the rpm will shoot back up to 1300 or 1500. some mornings it will crank up fine and not do it but the problem of it sputtering and missing will still happen. unrelated to this but anytime I go and crank it up warm I have to wait for about 30 seconds for it to lope or it will bog down or jump in the road. I have some throttle problems as well. If I press the gas real lightly like taking off in first gear it will sometimes buck and jump spilling my coffee and will not stop till I take my foot off the gas. codes I had today
KOEO CM 18 I replaced the TFI) (KOER code 41 the O2 is new and hasn't fixed the problem). I have checked for vacuum leaks with ether several times and found none.
List of parts changed:
TFI
PIP
TPS
IAC
IAT
ECT
3 ECM's
O2 sensor
FPR
In-tank fuel pump
in-line fuel pump
both fuel filters
air filter
I apologize if my grammar isn't perfect as I'm running on little to no sleep. The hurricane did a number on GA and have been trying to clean up. Any help is much appreciated!
Thanks
TFI
PIP
TPS
IAC
IAT
ECT
3 ECM's
O2 sensor
FPR
In-tank fuel pump
in-line fuel pump
both fuel filters
air filter
Thanks
