I have some asymmetrical play on my front drive shaft by the transfer case. See the video. If I understand correctly under the boot is the slip yoke that slides into the transfer case. Or is the slip yoke part of the shaft assembly?
In one axis it has movement, if I rotate 90 degrees there is none. Is that too much movement? Seems like quite a bit to me. I am currently pulling the u-joints to see their condition and if one may be binding explaining why no movement in the other direction
Video here http://youtu.be/FXZZDP4lx8c
Any suggestions on this would be appreciated.
Thanks.
Thanks.
