beecubed
- Oct 17, 2007
I have searched the forums and have seen a lot of reference and recommendations to replace the input bearing on an FM146 transmission when you have a chance (transmission out of the car), as that is a component that is prone to failure. Is this something fairly simple to do? It appears that the front of these transmissions (behind the bellhousing) have a "bearing retainer plate" that comes off, allowing you to perhaps replace the bearing without breaking into the transmission case.
Am I reading this right? Any help is appreciated.
Thank you,
Bernie
Thank you,
Bernie
