Fm145 question
87RangerXLTct
Connecticut
2.9 V6
Stock
Total Drop
Stock
235/75/r15
My fm145 started making noise in my 87 ranger 4x4. Changed the fluid, it was down about 3/4 quart. That didn't help much.
Did the 2.3 4x4 rangers use same tranny? I found one near me, was thinking I can just swap bellhousing? I imagine the bellhousing is removable, would this work?
Yes swap bells you should be golden.
2.3s prior to 1988. 88 up had M5ODs. 86-87 is your best bet.
FWIW the FM145 in my '87 is very noisy, has been for a while. Keeps on going though. Might last quite a while longer.
Thanks guys.
Shran- how long has yours been making noise? I might just get AAA and keep driving it while I gather up the parts. Definitely going to need a trans crossmember as well. The bushings on mine are toast
