- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Im getting closer to getting my 86 B2 ready to roll on the road (just the rear sill and a few wiring/brake issues left).
This is the first RBV ive owned without a TK5 speed. I know the mitsu is generally regarded as the worst for reliabilty manual used in these trucks. This one shifts smooth and is very quiet and id like to do my best to keep it that way.
1- What are the usual failure modes of this trans? So i know what to look out for.
2- Fluid type? I plan on changing it out.
3- If the trans does take a shit...the TK5 is a direct bolt in correct? Transfer case and all? Yes i know most guys swap a M5OD in but if the TK goes in directly ill use one...seeing as how ive never had any issue from one.
4- What is usually the biggest killer of these trannys? I dont plan on using it hard, just some minor trails, DD'ing and maybe very occasionally towing my little 6x10 trailer short distances with my quad on it (1500lbs total...maybe, my ranger tows it just fine)
5- Regarding the T-case (manual)...i know its a BW 1350 (or 54) but what fluid goes in that? Its also silent and works well but does leak a little. Id just like a concrete answer.
Thanks in advance.
Thanks in advance.
