ncsdaonex
- Dec 5, 2008
i put a brand new flywheel, and clutch in my truck and i hit the rev limiter and the motor started making a loud tapping noise. i got a mile or two and the timing belt ripped. so i pulled the motor and took off the tranny and discovered that the flywheel was loose. i had the bolts very tight but i didnt use a torque wrench. now my clutch wasnt working either and i found that the bolts on the flywheel loosened so much that they were hitting the clutch plate and that must have been the squeling noise i heard. now i had blue locktite on the flywheel bolts. why did the bolts come loose? i am planning on using a torque wrench and torquing them to about 62 ft lbs, i am also going to use the red locktite.
