flush mount tonneau cover 83-92
I've never even seen a flush mount tonneau cover. I've seen them just over the edge sitting on an aluminum rail that runs inside the top of the bed side, but even those I haven't seen for a while.
The one in your image is probably many decades old and more likely discontinued since nobody in North America actually makes a truck this size anymore. You might be able to order one custom, ore even make one yourself...but the box pretty much needs to be in perfect shape as any deviation in the side walls will result in gaps...
Probably never was water tight and meant more to keep eyes out than dirt or moisture...
Closest I've seen to that is what this guy demonstrates in this video...the rails are part of the install on this too...
http://www.partsengine.ca/t-Products-Tonneau-Cover-BAK-VP.aspx?gclid=COW18NKXiMgCFVY0aQod_XAFig
You should note the truck is an F150 and also that the price is around $1,200 CAD...or $500 USD with the dropping Looney value...
Does anyone know of anyone one that offers a flush mount tonneau/bed cover.
Here is a pic of what I'm looking for..https://lh3.googleusercontent.com/-...AAAAAB-A/388dYqGizxU/s800/20120221_174157.jpg
Rad are you wanting to remove it at all or just keep it on for looks. What color is your truck?.
Sorry I have no pictures of it anymore but I made one using some 'T' steel under the bed rails. Spot welded it to the underside. That gives you a place to but a 1/2 inch sheet of Melamine. You know the stuff they make closet shelf's out of. It has the white smooth top and bottom. My truck was white so it matched perfectly. Had it on there for like 5 years. Looked Great.!!!!
just a update,,,
The ones that i seen were the brands named,urban industries slim top tonneau cover and checkmate.
i doubt they are made anymore, infact urban industries does have a website that states they no long make them.
i might make a homemade one.
