kenwheeler
I have an 88 Ranger 2.9 4x4. What type of fluid does the trans and transfer take? Its the "145" transmission. I thought 80/90 gear lube but when I double checked at the Advance Auto counter their computer says Mercon Automatic trans fluid. If thats what it takes, what type of Mercon should I get?
What goes into the transfer case?
When I dropped the trans to replace the clutch, the fluid was a heavy brown color. How do I drain all the old fluid out to replace it with new? Can I drop that pan on the bottom? The one with all the bolts.
