fluctuating oil pressure
olranger
illinois
i have a 2.3l in a 91 ranger, i have been told it is due to the oil pump need cleaning or replaced i cant remember. Does anyone have any ideas.
have it checked with a manual gauge.
it will tell you the true pressure.
on a high mileage used vehicle i woud try an engine flush to start with. the pickup screen may have a partial blockage.
if your going by the factory oil pressure gauge, its just a glorified dummy light. id varify the oil pressure with a mechanical gauge like copperhead suggested. if your dropping below 8 PSI regularly you have an engine problem. if not, you have a factory gauge problem.
Pull the pan ASAP the pickup screen is plugged and needs to be replaced. These are notorious for this.
Some early 2.3L Rangers had problems with oil pan gaskets. With constant heating/cooling of the engine, the cork gasket would become hard and start to disentigrate. The pieces of cork would fall in the pan blocking the pickup screen.
Symptoms were: good oil pressure at start up. As the engine warmed, pressure would fluctuate, dropping as engine speed increased, rising again at idle, and variations thereof.
Cure is to replace the pan gasket.
Some have been able to drop the pan enough to get the crud out. The pans will not come off with the engine in the truck.
Some have been able to get enough of it out of the drain plug hole to clear the problem using a coat hanger or some such.
Most pull the engine, clean everything up, and install new gaskets. This is the correct way to solve the problem.
However, as others have suggested, make sure it is not something as simple as a bad pressure sender or gauge.:)shady
