PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
Soo. I have an 8 bolt crank from a 98TM motor that had the lighter pistons..can I get away with running flat tops or even 90-94 pistons and still be balanced?
I know the 99-2000 cranks are actually lightened and aren't compatible with the heavier pistons, but are the 98 8 bolt cranks okay with the heavier piston?
(Plan is to run 95TM heads to get the compression up a bit)
EDIT: Did a little more digging.....scratch the flat top idea...13:1 is a bit to high for my application, I want to stay on pump gas. I am looking for 10:1 or so (90-94 pistons)
