tailgate.
Remove the rear lamps (13404); refer to Section 417-01.
Remove the body side panel step mat(s).
Remove the body side outside upper moulding(s).
Remove the plug buttons.
Remove the screws.
If removing the LH body side outer panel, remove the fuel filler cap.
NOTE: Mark the position of the fuel filler cap tether for proper installation.
If removing the LH body side outer panel, remove the filler neck screws.
If equipped, remove the mud flap(s).
Remove the rear wheel splash shield(s).
Remove the five screws.
Remove the five pushpins.
CAUTION: Use care not to scratch the pickup bed.
NOTE: Label the pickup bed bolts because they are not identical and must be installed in the same location that they are removed from.
Remove the pickup bed bolts.
With the aid of an assistant, move the pickup bed toward the rear of the truck enough to access the front panel to bed bolts.
Remove the step screws.
Remove the rear lamp opening bolts.
Remove the lower rear body side outer panel screw.
Remove the three front panel to bed bolts.
Remove the body side outer panel(s).
Remove the screws.
Installation
Install the body side outer panel(s).
Position the body side outer panel(s).
Install the screws.
Install the three front panel to bed bolts.
Install the lower rear body side outer panel screw.
Install the rear lamp opening bolts.
Install the step screws.
With the aid of an assistant, position the pickup bed.
Install the pickup bed bolts.
Install the rear wheel splash shield(s).
Position the rear wheel splash shield(s).
Install the five pushpins.
Install the five screws.
If equipped, install the mud flap(s).
NOTE: Position the fuel filler cap tether.
If installing the LH body side outer panel, install the fuel filler neck screws.
If installing the LH body side outer panel, install the fuel filler cap.
Install the body side outside upper moulding(s).
Position the body side outside upper moulding(s).
Install the screws.
Install the plug buttons.
Install the body side panel step mat(s).
Install the rear lamps; refer to Section 417-01.
Install the tailgate.
