flared fenders
jablome483
northern NY
Would it be possible to fit 33 in tires on an 01 4x4 ranger with a tbar crank if i get flared front fenders, or am i going to need a body lift? Im asking because i dont really like the look of a body lift and i do a fair bit of hauling in my bed and dont like the idea of it not being supported by the frame, but would like to upgrade from the 31s i have right now.
33x12.5 will rub on your sway bar with or without fenders. T-Bar crank might help but it won't go away. Flared fenders on a pretty much stock truck would look weird too. If you really want 33's get 33x10.5 and a T-Bar crank with shackles and you would be good to go. If you go off roading 33's will probably rub on your fenders though
dont flare em, trim em i run 35 13.50's on nothing but torsion keys n shackles and don't touch a bit rub a little on the inside but nothin a couple wheel spacers can't fix
What happened to your 33s? Text me a pic of your truck dude.
But ya I forgot about wheel spacers. You could do that but expect some parts to get worn out fast
the tires i will be getting are 285/75/r16 so they should be about 11.5 in wide. im not going to cut up my fenders, i can take a bit of rubbing because i dont off road frequently. i guess ill get the tires and see how it goes
