lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
I have a set of torches (which I got first) and a Lincoln AC-225 (220 volt AC stick welder). I picked up the stick welder for around $100, got a pile of rods with it too off of Craigslist.
But I've discovered that stick welding takes some practice. A lot of practice in my case.
The first welding I learned how to do was with a torch set though. Oxy-Act. Never practiced, just gave it a try one day, figured I had a pretty good idea of how to do it and the welds didn't come out half bad. My first bead I laid down didn't penetrate quite enough so I heated and worked the weld again. The second bead I did came out a bit nicer. Then I didn't touch the torches again for awhile until I was working on fixing the ladder rack on my truck. Laid four short beads that were picture-perfect (a lil wide, but there wasn't really any way to help that). Then I laid three vertical beads that came out fairly nice. But I've had experienced welders that have scratched their heads and said that they thought torch welding was the hardest to learn.
Nice thing is with the torch, I can switch tips and cut through steel, although now I have a dedicated Oxy-Propane rig for cutting.
Look at it as an investment that will last you a while. Get the best you can afford.
