First timer
honda34dad
Texas
Hello,
First timer that is needing a little help. My dad has a '78 Ford Bronco on 44s that we take out to RWP. I am interested in getting a 4x4 Ranger to make into a mud truck to find the holes. He can pull me out and we won't require a MONSTER truck to pull me out, he can do it. What I need help on is finding a way to make an extended cab ranger work well for a family. My wife and I could sit in the front, but we have a toddler that I would like to take mudding as well and even the extended cab '93 ranger I am looking at, does not conform to my wants/needs. Has anyone had any experience with getting a bench seat in the back of a ranger or even cutting out the back wall and mounting it between the bed and the cab. Any help is appreciated.
Welcome to the forum
You could look at Explorer sport trac, it has the bed and 4 full doors with rear bench seat, its about 700lbs heavier than Ranger
Extended cab Ranger 4x4 3,600lbs
Sport Trac 4x4 4,300lbs
But yes, in a Ranger, you could pull out center console and make a seat in the middle, child's legs would be where center console was, so he/she could face forward, the standard jump seats have child facing sideways
There is really not enough room in the cab for forward facing rear seats, as is
4-door Ranger rear seat pics here: http://gtcarlot.com/data/Ford/Ranger/1999/6698195/Rear Seat-92368332.html
Same as 2 door seats fold out but face inwards
No on modifying the cab, there would be some structural issues for what you want to use it for
Welcome aboard! Lots of helpful folks around here.
Welcome to the site. Good luck with search.
I know when I was building buggies... they use to make a smallish fiberglass shell bench seat. It would require you to build a roll bar hoop internally. Then brace it to the floor coming forward... then a couple cross braces and four tabs mount the seat. Add a four point harness and center it so the young ones legs come between the seats.
Ended up taking an easier route and got an ‘86 Bronco 2. Hope to get stuff from a ‘78 fullsize Bronco. Hoping to use the motor(unsure because of fit and lack of AM motor mounts), the tranny, front and rear ends, and the transfer case. Already planning to get a 2” body lift to help it fit in. Any ideas if a 3” would work better, since the 351M is a taller motor? I am not afraid of cutting metal to make some 35”-40” tires fit.
I think 3 inch is standard now days... you might find a 2 inch though.
I would suggest starting a new thread over in the off road truck forum... it will get better looks over there. Then ask all the questions you want about your build.
Good luck and looking forward to seeing the progress.
