first drive!
FirstRanger86
For anyone who missed my original thread, I bought my first ranger at a farm auction and it had sat for 15 years. I finally got the 86 XL on the road yesterday! The suspension, brakes, and steering were surprisingly good! Good oil pressure, ran cool. It was great to have it rolling again.
Two things: Still running rough, despite full tune up, surges frequently, and even stalled while cruising on the highway (luckily re-started in neutral)!
I have to run the ECM tests again, but I was getting an 02 sensor code and an EGR sensor code - replaced the 02 sensor. Could the EGR/sensor cause a rich condition, and rough running? I thought maybe I'd take it on a few highway runs and see if I can blow anything out, and run a tank of good gas through it (and fuel injector cleaner).
Exhaust - what a pain. The cats are good, the tailpipe is good, the midpipe and muffler were toast. Trying to get this thing on the road as cheaply as possible, I was going to put some flexi pipe between the cat and tail. But with the rich condition, I was seeing smoke coming out under the hood. The gasket between the downpipe and the cats was shot, so I swapped it out. Unfortunately, it's still leaking, the flanges must be warped or nicked up. Should I put two gaskets on there? Is it worth it to use that exhaust sealant in a tube crap? Because of that two-into-one setup, I can't easily cut off the flange and make duals or something. Any creative ideas?
Thanks!
Tom
Well...sounds kind of like my ranger. Mine's an 88 that sat for 15 years also came from cali...Mine is a 5 speed and it would start splurging and running bad going down the road and occaisionally stall...but the o2 sensor fixed it for me...also cleaned the throttle body...but it wasn't that dirt considering it only has 88k miles. Mine also ran rough the first few times ( a lot worse than just the o2 problem) so i put 2-3 tanks of premium in it, then it runs great on regular now...best of luck!
Thanks. It's still running rough, stalling unless I keep my foot on the gas at all times! Once it stalls, too, it is very hard starting. Given that it's been sitting, cleaning the throttle body is probably a good idea. Someone mentioned, way back when I first couldn't get it started, that removing the injectors and soaking them in solvent might be a good idea. Silly question, how do you remove the injectors?
The black smoke has gotten much better. I actually just ordered an 88+ cpu, and am going to block off the EGR, since it was giving me a code. I figure it takes one more problem out of the list of potential causes of running badly.
