my schematics show nothing between the injectors and the computer
white/tan straight to computer
Red wire goes two places
1. Idle Speed Control Solenoid
2. Runs to a conjuction off the ee/fuel pump relays and other 12 volt references for other sensors
My book is a 1989 Shop Manual.....I assume this is for the 90 ranger in your sig?
"On the closed bowl distributor, the pip sensor sends 2 parallel output signals. One signal goes to the externally mounted TFI-IV ign module for "STAART" and "Limited Stragety" mode operation. The other PIP signal goes to the ECA to allow the computer to calculate crankshaft position and RPM in order to control Timing and Fuel Injection."
I had a EEC relay go bad. But i started diag the no pulse at the injectors before i realized i had no spark and no pulse at the same time. Ended up a bad EEC relay. But i have replaced several TFI (Ignition/Control Module) modules as well creating the same condition.
For
