86MUDRCJ
Found a sploder for 500 the tranny is bad but thats it. Heard that the motor will bolt up to a 2.9 tranny?
I will be im just gonna run it till i can rebuild that one or get a different one.Yeah, it will bolt up fine. But the 4.0 typically shreds any tranny (with the exception being the not-so-common M5OD that came behind the 2.9L) that came behind the 2.9.
But, I did run a FM145 behind a 4.0 for a while and it did fine..just be easy on the throttle.
I think it should. But there is more to it than that.
I thought there was more to what the swap required. Should work good as long as you use a 4.0 clutch.
