Finally, my official project truck
Any ideas how the parts could be deleted?
I assume pats
Dusty thread that's still moving....nice work on the bracket.
You can get a non pats pcm ...or use
Sct or hp tuners.....call your nearest tuner and explain your goals. They will help you.
I love them! Front spacer is needed to run rhw center cap. Everyone said get 1 inch spacers, and I did..BUT..I'm ordering half inch spacers..pretty sure that's all is needed...
So today's agenda..get the ac chilling! It works as it should and the cooling system works as it should...
I know a guy that can delete PATS..he's not just a tuner..he owns a twin turbo daily driver with ac ranger..pm.if you or anyone needs his info.
Oh God. I'm in Lagos, Nigeria. Was thinking it's something that I can delete myself.
The 302 Ford engine is from a 2001 explorer.
Is the explorer.still available? If so get ready key and ignition switch, ring around the ignition switch,PATS from behind the passenger air bag, if your truck is a 99.or newer, it will plug right up
His truck is 95
Ac is working flawlessly... let it idle for 15-20 minutes.. Everything is absolutely perfect! Fogged up the windows even! If it was going to over heat...sitting at idle is normally where it happens
Now to figure out which way I'm going with the suspension... get that done.. and make it's first 1200 mile trip to Florida this summer. Might meet up with Jeff down in Central Florida to get a pic of the twins together..although his is much nicer than mine!
Nice wheels. What sizes are they?
