Finally My Lift Is Done
Ranger_Boi
Yakima Wa
it took a wile to get here but its done. i pruchased the tuff country 4in suspension kit and man it was a bitch to get on but now it looks great.. u be the judge. THE REAR IS LOWER because i had to take my overloads off so my liefs are a little ware there being re-arched as we speak
HERES THE STOCK PIC
HERES THE LIFT
AND HERES THE FINISHED PRODUCT
yah they were a bitch we had to cut the rivits and then put the new braket with bolts above it
just saw this on one of the power block (spike tv) shows. they said the easiest way is cut a t in the top of the rivet with a 4" grinder then air chisel with the little auto chisel from sears or where ever. I KNOW HIND SIGHT IS 20/20:icon_confused:
its not that bad doing to brackets for a lift. leaf spring hangers usually are much worse. i took care of all my rivet grinding for my factory radius arm brackets and passanger beam in about 3-4 hrs. but i am well versed in the rivet grinding fun.
86
86
they really should only take a minute or two a side if u have done them before
wish i had an older model like that just to lift it b/c it would be hard to make a lift with the newer a- arm set up
