- Oct 22, 2008
- 2.3 (4 Cylinder)
Bellhousing bolts.
I've been able to get the tops with a box end wrench from the top, tapping with a mallet to break it loose. You'll have to crawl up in there on top of the engine to really get at it.
What I've done more often, especially on V6's, is use several extensions on a ratchet or breaker bar and just go up over the top of trans with the extensions. This may be a problem for you, since you don't want to lower the mission until you get the bell bolts. If you get the jack under the mission, pull the rear crossmember, lower the mission a little, it's almost a straight (but long) shot to the upper bell bolts.
I may end up having to drop the trans a little, but I want to try with just the long box-end first. Ordered one from HomDep.
Thanks, appreciate the advice!
