film ignition?
jamesberk
sorry I make so many threads....
so when I fist got my range someone asked me if I had or planned to switch the ignition to film? or something like that. What does this mean and what does this do?
Probably talking about the duraspark swap. Check the tech library.
ok. so what is the advantage to this duraspark swap
eliminate the TFI or thick film ignition that is controlled by the computer to the duraspark that controls the advance with engine vacuum. You cant do it if you have to pass emissions.
you can't do it on a 2.9, the 2.9 needs the TFI setup to run
