Fender Removal
I need to pull the right front fender on my 92. The "all weather cab" is now a fair weather cab. I have found the leak I think, but need to get the fender off to repair it. Can anyone tell me where all the bolts are located? and any other tips? Thanks.
You can probably get away with just removing the bolts from under the hood, inside the door, and at the bottom of the door by the rocker cover...but if you want to remove it totally then you may have to remove the grill piece to get at the two bolts in there...and there may also be some at the bottom/front...
It's usually easier to just look at the fender and how it's mounted than to desribe the bolt locations, and I think there may be ten at most holding on a fender...and the last time I did it mine took a number 8 metric socket...
