fender ideas
CheapThrillB2
May 2010 OTOTM
OTOTM Winner
Solid Axle Swap
Western Michigan
1975-1995 Ford
I need some fender ideas and rear 1/4s pics and such.....i need MAX clearance. I just lowered my truck 3"s and need to clear 36's. I need shots of max clearanceing on fenders and qauerters.
I've seen next to nothing for the rear of B2's. Other than glass quarters.
One PITA with the BII rear is any trimming opens up the interior to the outside (if you need to keep things sealed anyway). I used some of that expanding yellow foam-in-a-can stuff you get from Home Depot, Lowes, Ace, etc. to fill up the gap.
I also cut the inner tub and moved the rear part of it back 3" then welded it back into place.
(I can get you some better pics tomorrow when it's light out)
-andrew
Haven't seen it done that way yet :icon_thumby:
Here's what I did on mine:
Some guys just cut that whole inner tub part out of there and use new aftermarket (larger) ones. I didn't want to intrude too much on the inside though (keep in mind my rear axle is moved back almost 3" as well). You can see the gap at the edge filled in with the foam stuff in the 2nd pic (I spray-painted the foam black so it "matches" a bit better lol)
