professor229
Will try to make this quick.... I tried to do some fill welding on the few rusts spots on the wheel arches... The damage was to extensive so I got out my grinder and removed the damaged area trying to leave a good lip on the bottom and yes, there was still some good metal there... I am going to fabricate my own patches out of the old removed fender that I replaced and I have a flare tool I have used before that works extremely well... If the fender patch metal is too thick I will buy a sheet of weldable metal and use that... any idea what gauge that should be? The plan is to weld this patch in place and grind welds... fun.... and then cosmetic bondo etc.... When I am done I am hoping for the best but will cover the fender arches with aftermarket fender flares.... I don't want to throw in my billfold.... cheap set will be fine... lots of them on Ebay... anybody buy any of them and were you happy or disappointed? Bolt on, rivet on, or glue? Would just like to hear the good and bad before I order some off Ebay.... Thanks for your help.
