Rex2nr
I have a 99 Ranger, 4.0 4wd with a 5spd. This started last fall but went away after replacing the TPS sensor. It is now coming back. There is no check engine light, but I don't have a scanner to check for pending codes.
It only does this when the engine is up to temp- the idle remains at 1900-3000 RPMs when slowing down, or coasting after slowing down from highway speeds. If I tap the gas, I can get the idle to settle back down to ~800.
Last fall I checked for vacuum leaks, found none. I cleaned the idle control valve, which made no difference. I cleaned the MAF, and replaced the TPS (I did get a TPS code at that point). Yesterday, I cleaned the contacts at the TPS and idle control after reading about this being an issue on the 2.3s, still acting up this morning. I also checked the battery/alternator. my battery was sitting at 11.8 (a bit low, but I don't think its too concerning) and the alternator is putting out 13.9 volts.
The other weird thing is that the oil pressure gauge clicks and jumps all over when I tap the gas to get the idle to settle down. When driving it acts normal, just erractic when trying to settle the idle.
Do you think I'm looking at a ground issue or voltage issue? It seems too coincidental and the only thing common is they are electric... i'm lost.
Thanks
Thanks
