here was the start of the motor swap last weekend
as you can see this motor is taller than the old motor that we dropped, the stock intake was right were the cross brace goes...
our solution, which we only did in case we ever wanted to use the stock intake manifold
FAST Fabriction wil be designing and fabricating a custom aluminum intake manifold that lets the air go directly into the heads, instead of to the back of motor and then forward and down into the heads. Should gain horsepower but that was not our goal, we will do a dyno with the stock and with this one and offer it to the public after we have had a few races on it. Basically we will replace these pieces, with the idol control being remounted on the new piece and the important lines
So to drop the motor pass what we already had dropped the first motor with our mounts, we had to make some room on the crossbrace, and bang in a bump in the firewall, we went down another 1" plus and about 3/4" more back. Overall from the original OHV location I would ay we are somewhere between 2.5-3" down (bigger pan on the sohc so hard to be sure) and went back probably between 3-4", the c4 transmission has dropped an 1.5" from where the stock 4.0 was after we had lowered that motor.
decided to take advantage of motor being out, instead of trying to shape and close those huge holes on top of the firewall, we cut it out, going to cut the inner piece out after looking at the damage to if from before, will replace with a 18 gauge piece with a rosette plug flange that has a 90 and goes straight down to the firewall.
that was last sat and sunday.... today we completed the motor mounts and check all our clearances, and will knock out out transmission mount that will have a drop out center for easy removal as well as hold the dual exhaust
originally we had this barely away from that flange and still had plenty of room everywhere else, but we decided to bring the motor forward an 1/8 and settled here
trans height
we also knocked out the remaining engine braces, going to mount skid plate first tomorrow, now that we can put the bumper back on, should go fairly quick one tube is already done
just placed an order for FAST Fabrication hats, flexfit with two embroidered designs, the t-shirt design is nearly complete, and that is how i spent my 27th bday
going to stay home in oc next weekend cost to much to work on it for two days, spring break is the following week, will get 8 full days of work and will be able to finish all the fab work )as long as I get the new dash by then) so we can start on running all our plumbing and electriical lines
