Fast blinker
94STXRanger
Kansas City
Hey guys,
Im working on an 01 Jetta that has had some lighting issues. First the tail light was not working, then turn signal, then a different side brake light. Anyway i replaced a couple fuses and got most of them working again.
Now when i turn on the right side blinker, all lights flash and they flash at a normal pace, even though a sidemarker bulb is out.
But when i turn on the left side, all bubls flash, including the sidemarker, but they are twice as fast. I figured it had a bulb out, drawing less amps and flashing faster, but every bulb is good.
So my question is what else will cause the flasher to flash so fast on only one side with all bulbs functioning?
Please help,
Thanks
Check the bulb holders. You might have one that's feeding both filaments at the same time.
