Fan upgrade?
socal_Redranger
Forum Member
Riverside
CA - USA
Drive
2"
33s
I was thinking about changing the fan on my 09 to something beefer, since I plan on building a prerunner. Somewhere I read about upgrading the fan can help free Hp, the better cooling would be nice too. I saw people on eBay selling a cheap fan and radiator kit, or some fans on summit; but I was wondering what you guys have done. I was thinking about going to the junk yard and pulling a fan off some other car, along with a larger trans cooler.
Your plan of going to the junk yard is a solid one. I went down the cheap fan route. Bought a electric fan from the local store, largest one they had (16 inch) was supposed to be good enough for a big block engine. I had two of them I mounted side by side on my diesel truck, would not cool it. Had them sitting around and decided to put one of them on my stock 2.9 v6. Would not cool even that little engine.
I went to the junk yard and got one of the famous 2 speed taurus fans. Mounted it in there and it cools it on high speed. I did not get fancy with some sort of low speed/high speed control. I just wired it for high speed. When it comes on sitting at a stoplight, I can watch my aftermarket temp gauge start falling.
One problem, when you get a real fan like this, they take real power to run them. I checked the cheap aftermarket fan, it took about 8 amps to run it. The taurus fan took about the same amps on low speed, but took about 12 amps on high speed. So I had to make sure I ran a relay, I was using the direct style temp switch and I was afraid it would not handle that long term. It did load the stock alternator down pretty good, but it handled it ok.
P.S. You can get the taurus fans new on Amazon if I remember correctly. Do not know about their quality though, I found a used one cheaper at the junkyard.
Bigger radiator (V8 Explorer has a bigger one, I’m running one out of a 00 in my Ranger) and an electric fan, preferably a two-speed like the Taurus fan.
For a trans cooler, I got one out of an 07 F-150 and modified things so it fits behind the grill. It’s over twice the size of the stock cooler.
@socal_Redranger
Of all the changes I've ever performed the sole change that made the greatest improvement in fuel efficiency is losing that crankshaft driven fan/clutch for an electric fan (needs to move at least 2,800 cu.ft./minute), don't waste your duckets on a lesser fan. In regards to power, it will not make more power but it does reduce the load loss by removing 8-9 lbs. from the crankshaft; so it is restoring lost power ..)
@lil_Blue_Ford , I have never thought to use the V8 fan 🙄
@franklin2 , with a 15"-16" fan capable of 2,800 cu ft/minute I've driven throughout the summers in both Arizona and Southern California, no problem. Only had to run.them at speeds below 35 mph, towing or, obviously at stop lights.
@gaz , you need to read my post better. I said a V8 radiator. The 95-01 Explorers used the same radiator as the Ranger and much like the older 4.0 Rangers, the 5.0 got a thicker radiator that fits 98-11 Rangers.
Did some googling the f150 cooler looks to be twice as wide but half as tall. But I can find a picture if the stock mounting, so I have to pull it and go from there. Thanks for the recommendation.
@socal_Redranger
Of all the changes I've ever performed the sole change that made the greatest improvement in fuel efficiency is losing that crankshaft driven fan/clutch for an electric fan (needs to move at least 2,800 cu.ft./minute), don't waste your buckets on a lesser fan. In regards to power, it will not make more power but it does reduce the load loss by removing 8-9 lbs. from the crankshaft; so it is restoring list power ..)
yeah I said "help free Hp" Because its not like changing the fan adds power it just frees up power going to accessories from the crank.
@lil_Blue_Ford
That was a typo on my part, I knew you were speaking of the v8 radiator, I must have accepted an "autofil", then not proofed it 🙄
I’ll have to find some pictures and video later, don’t have time at the moment. I ditched the stock mounting for the F-150 in favor of making my own mounts. Well, actually @sgtsandman fabbed them up for me when he was helping me work on the truck. I had to modify the grill support and it worked out nice. The one I got is over twice as wide and like 3/4 of the height.
@lil_Blue_Ford
I like the appeal of a single transmission cooler. I will check into the F-150's; a dual Explorer transmission cooler setup is also solid, it is esily aquired, simple to mount, just more hose routing 🙂
@lil_Blue_Ford
Its apparently in my build thread…
Get a bit of video in this one…
got pictures of what you came up with?
See my above two posts, there’s a tiny bit of video of it in the video posted and pictures in my build thread post that I linked. If you click on the red banner “Post in thread ‘My 2000 Green Ranger 5.0 lowered AWD’ it should take you directly to the post with pictures and a short description.
