Leave the fan belt on, that helps.
There should be a label in front of the rad that tells you if it's a CCW or CW to remove, if it is gone then you will need to look it up by year and engine, they are not all the same.
There is a Ford tool set to hold and remove fan clutch.
Just flat steel open end wrenches.
The one needed is the one that holds the pulley, it is wide and slides down the edges of the 4 pulley bolts, so all 4 bolts are used for leverage to hold pulley while fan clutch nut is unscrewed.
Most people have a wrench that fits the fan clutch nut.
The Ford tool set runs about $20, often you can rent them for a few dollars, check the auto parts store where you will be buying the water pump.
You could also use a strap wrench on the pulley if there is room.
There are a few ways to get leverage to prevent pulley from turning but these can bend the pulley
