Fan clutch pully in a 4.0
Jhm
Texas
The fan clutch pully on my 1992 ranger with a 4.0l engine got bent and messed up. I can’t find a replacement at the auto parts stores but I did find one for a 1993 exploder/ranger with the 4.0 these should be the same engine is there a different in the fan clutch pullys
Should be the same. Not sure why but often I have to search for parts for an Explorer when working on a Ranger... or vise versa, it is annoying, they are the same.
May be different offset as some/most explorers ran a thicker radiator.
If shorter it would still work but the fan may be more out of the shroud.
@Jhm
A great opportunity to delete the crank shaft driven fan/clutch for an Electric fan. You will be happy with yourself everytime you buy fuel in the future.
If the damage isn't too bad, you may be able to bend it back. Then a little emory cloth or sandpaper, a splash of rattle can...DONE
I did Bend it back once and it made my water pump go out so this time I want to just replace it/ and I did order the pully from O’Reilly so we’ll see if it works
