- Jul 20, 2008
- Automatic
I have a 99 Ranger (3L Flex-Fuel) with 82k and started using E85 about 2 months ago. Two weeks ago I was coming home from work and it started running really rough, especially at low RPM. The check engine light did not illuminate. I noticed some loss in power as well. When I got home I started taking off plug wires and when I removed #5 it had no effect. I tore it apart and found that the fuel injector on cylinder #5 had no ohms of resistance (the needle on my voltmeter wouldn't even jiggle). So, I replaced #5 fuel injector (and plenum gasket and all spark plugs and plug wires) and everything was great...until today when it started running exactly the same way... When I removed #5 plug wire this time it ran rougher (so that's not my problem cylinder), but when I removed #6 it made no difference. Granted this is an assumption but before I'm able to tear it down I'm going to assume that I'm going to find no ohms on #6. What is causing my fuel injectors to fail? If they we're getting plugged I'd blame the E85, but with the loss of electrical continuity inside the injector I'm totally puzzled. Any help would be much appreciated!
