Raynman
Failed Smog Check In California!!!
Last check... ( 2 yrs ago) I replaced cat,o2 sensor ( only one in my vehicle) and that did it. I bought a code reader and got these codes: 157-MAF fault, low voltage 172-HEGO sensor fault lean 173-HEGO sensor fault rich ( does this seem weird, both lean and rich) also, 176 - HEGO sensor fault always lean....also code 189- HEGO sensor fault unable to switch/lean during part throttle....why is HEGO ( o2 sensor) coming up with all these codes??....it's only 2 years old!!! And, last code was 212-loss of ignition diagnostic monitor signal/SPOUT circuit grounded. Where do I start?? I knew my coolant temp sensor was bad, so I am changing that. I will also install set of plugs, clean MAF, Change oil, and see. I really could use some insight if "DieHardFord" is out there, or any other SMOG experts!!! Please Chime in!!!!
