Factory Water Temp Gauge
fastford04
Northeast, TN!!
I took my factory water temp gauge out because the temp gauge in the dash is bad and doesn't work so I installed a sunpro one.
Started the bronco it wont idle starts runs an dies..
Well after a few minutes of tinkering I discover that the factory water temp gauge must be plugged in for it to idle...???
Which leads me to my question.
Can I just leave it plugged up and e-tape an zip tie it back out of the way? Or can I cut the plug off of it an put a butt connector on it?
Just curious what someone else has done or if you've encountered this problem b4 thanks!
Tiny
There should be 2 sensors, one is for the computer, one is a sending unit for the gauge.
You have the wrong one.
well the one that i took out is pretty much directly behind where the thermostat is it has 2 wires coming out of it. theres another sensor to the right of it that has one wire coming from it.
cause I bought a new water temp sensor from autozone an the one they gave me an the one i took out of the truck were the exact same temp sensor...
http://www.autozone.com/autozone/ca...+Temperature+Sensor&searchText=coolant+sensor
heres a pic of the sensor.
So wich sensor am I supposed to remove to install my mechnical water temp gauge? The on with one wire or two?
