Factory rear sway bar sizes
Wicked13
What sizes are available from factory Fords that will fit my Ranger? I have a 1" bar on the front of my truck and no rear. I'm thinking a 3/4" would be a good choice with my front bar. The truck is stock height and won't be lifted or lowered. I do plan on a lower profile tire (235/60-16) come spring.
The stock sway bar size for the Ranger from 93 to 97 was 5/8-inch. The stock front sway bar for the same years was 23mm.
I've read that the BII 1-inch bar would also work, but I've never seen a picture of one installed on a Ranger, so I don't know
If you want a stiffer bar go hunting for a 2wd Bronco2 they have a 1" rear bar.
SOME '87-88 Rangers got a 3/4 before they switched to the 5/8" bar
I also have a 7/8" diameter rear bar off of a ranger but I cannot remember
what I took it off of as I've had it for 15-ish years...
AD
Thanks for the info! I'm trying to see what's available and make sure I do the job once.
