Factory FX4 Torsen LSD and Spacer Block Set
Mr. Bossley
Kelowna BC
Around 6-7"
38x15.5
Factory FX4 Torsen Rear LSD for Ford 8.8 31 Spline. 180xxxkms on it. No issues. Should fit explorer rear ends as well $150
Also have the spacer block set it. It allows you to run lower gears (4.56, 4.88, & 5.13) and keep the Torsen. No grinding of the ring gear needed. I bought it thinking I was going to keep my LSD but plans have changed so I wont be needing it anymore. Never used. Its made of 4140 chromoly steel by Blowfish Racing. About $250 USD new. Selling for $150
Located in BC Canada. Buyer pays shipping
Bump. I am now selling the Torsen Diff to go with the spacer set.
Do you know if a person can switch to a higher gear set (3.73 from 4.10) and still use the factory spacer set?
Going to a higher gear set should not be an issue. The ring gear gets thinner as you go down numerically so you would have lots of room.
