fabtech
small&mighty
Dallas area, Texas
I want to get a Fabtech suspension lift system from www.fabtechsuspensionkits.com, but it states that I have to use 32/10.50R15 tires w/15x7 wheels w/ 3 3/4" BS w/minor trimming. I don't want to shop around for 15" wheels and nor do I want to do some "minor trimming". I run on 235/70-16 OEM tires, which I just found out that its rare for a Ranger to have 16" wheels off the lot. So, my question is: Since my OEM wheels are 16", can I still ignore the "recommended" size that Fabtech posts? Or is this a size that must be obeyed? What would happen if I got 35" tires on my 16" wheels? Will it fall apart? lol
it will be fine..... you just need to look out for the overall diameter and width..... anything between is your business, it wont fall apart
You can't use rims with more than 3.75" of backspacing due to rubbing issues but the 32x11.50x15s are just a recommendation, you can ignore that but as for running 35s, your gunna need about an inch more of lift to clear em
