fabtech lift kit
schneiderz
Alpharetta GA
Hey do I need to get a complete lift kit or can I just get the lift springs and put those on to lift it without replacing my whole suspension setup?
Its a good idea to get the entire 2.5in lift. The control arms that come with it allow you to align the truck properly afterwards. But I've seen how much that kit costs. So instead, I'd get the spindle lift which costs less and would not alter your ride.
you can purchase individual parts from them but like mp3deviant721 said it'd be better to so a spindle lift. If you use springs that lift any more than 2 inches you'll need an upper control arm to go with it and new shocks for the front. I'm going to get a set of doetsch spindles when I get the money because you won't need new shocks and you only will need an alignment. They are I believe $437 after all charges for the pair which is cheaper than buying fabtech spindles.
ya i bought fabtechs 3 inch spindles and it costs $499 at 4 wheel parts but you also have to buy these cams that bolt on to the upper control arm to set the camber of the wheels for around $60. but other the that my ranger looks pretty good with just spindles
