Fabtech 3in Spindles...
It will be close. Here is a picture of my truck with Fabtech 3'' spindles with 31's
[/IMG]
33s on my edge no problem. I had them on there stock as well with a t-crank and some trimming.
No rubbing. 15x10 rims 3.5" BS by the way.
You have an XLT, he has an edge, an edge can easily clear 33s with a spindle lift, some people have even ran 35" tires with just a spindle lift and t-bar crank. It all depends on how much gap you want in that tire wheel (for flexing, etc.).
they will if you crank your torsion bars up a couple inches. im running 32s on mine and have plenty of room for 33s
Have any pics?
Yeah, I had the same 33s as pictured above on stock with a t-crank. Trimmed the spots you see in the pics but with the right backspacing that may not be necessary. Mine are pushed out wide.
I went to lift spindles because the ride was rough on the road. Felt good offroad, but couldn't live with it on road.
You're talking about the ride with the t-bar crank yes?
Have any pics?
yup here's one..
picture.php
Yes, the rough ride was from the t-bar crank.
Ride is good now with the lift spindles, as I was able to back off the t-bars some.
