harriw
Hey folks,
I know this might below in the full-size forum, but I'd like to ask those knowledgable with Ford engine computers in general, not just specifically F150's (though i don't really know if they work in the same way or not). If I'm out of line, I appologize - please feel free to switch this over to the full-size forum if you think it'd be more appropriate there.
Anyway.... I've got an '03 F150 4x4 lariat with the 5.4. CEL is on with codes 0172 and 0175 - both banks running rich.
My cousin brought his good scanner over, and we had a look at the realtime data. Sure enough, long-term fuel trim is pegged low (around -20%), meaning the computer is trying to lean the mix out as hard as it can but can't get there. So we took a look at the O2 sensor readings, and here's where it gets interesting. F150's have 2 cats and 4 sensors - one before and one after each cat. The upstream O2 sensors on both sides look like you'd expect them to be normally - they're bouncing from around 0.1V to 0.7V, as if they're jumping from lean to rich like they're supposed to. The downstream sensors are both sitting at 0.7V though (rich).
So, any thoughts on what this indicates? I guess I'm not sure which set of sensors the computer is using to trim the fuel mix. I would think it would use the upstream sensors, but they seem to be working normally so why the codes? Unless both upstream sensors are off together, and the downstream ones are correctly showing rich? But the cats should have burned off all that extra fuel right?
What do you guys think? Does this look like bad upstream sensors, bad cats, or bad downstream sensors?
Of course the other thing is that any of those 3 options mean that 2 sensors or 2 cats went out together, which would be unusual... Is there any single failure that might produce the data seen here?
Just some background, the guy I bought the truck from said the CEL was for the MAF sensor (he didn't say which code it was). Said he cleaned it, but it didn't go away. First thing I did was clean the MAF again, then pulled the neg battery cable to clear the code and see if it would come back. In hindsight, I should have had the code read first at least so I knew what was in there originally. Anyway, after cleaning the MAF and seeing the rich codes show up, I checked the MFA's output voltage. It's spot-on where it ought to be for various engine RPM. Air filter looks pretty good as well.
Anyway, any input would be greatly appreciated. Just thought I'd run it past you folks before I pay a dealer to have a look at it. Thanks a lot!
-Bill
-Bill
