F150 vs F250 TTB Drop brackets
mhughes165
Solid Axle Swap
i was just wondering, is the drop bracketry from a coil sprung f-150 the same as the drop brackets from a leaf sprung f-250, as i undetstand it they use the same exact beams if there a d44, so wouldnt the same brackets work, and u just have to get lift sprigns for the front??
the 44 beams with 8 lug, whether ld/hd, d44 or d50, were all different, beams and brackets compared to my 150 beams.. kind of a freak setup looking at it comparativly...though the the brackets look to be usuable for other applications. i was intending on putting a set in my 1 ton van in an attempt to keep the ride height down, since it is a psd there were other mount issues as well.
