F150 transfer case
rjustus1234
Boise, Idaho
I was wondering if i can put a 89 f150 transfer case on my 87 ranger? I can get one for free so just curious.
Well it won't just bolt in.
Even a Ranger t-case won't just bolt to your 2wd trans and make it a 4x4.
Where are you located? Maybe someone around you will have a Ranger t-case they are willing to trade for an F-150 unit. I have an e-shift case I'd trade for an F-150 case, but I won't screw with shipping them.
so what would i have to do to make a transfer case work on my truck? and im way over in idaho ha
In your case you need a different trans. You have an FM132, the 4x4 version would be a 145. I don't know that a 132 can be converted.
On the M5OD, and most transmissions, you can put the longer version of the output shaft in, bolt the extension housing on in place of the tail stock, and bingo bango, 4x4 transmission.
In your case I don't know if it is possible or not. I am not well versed in the internals of the FM transmissions and so I don't know if there are other differences between the FM132 and 145 that would cause problems.
You are better off in the long run to just find an M5OD anyway. It is a far superior transmission.
Actually the 4x4 version of an FM132 is an FM146.
I'm pretty sure you typo'ed
AD
well i just pulled a mazda 5 speed(i think its the toyo kogyo or something like that) from another truck i had would that work like the M5OD?
