F-150 Rims?
bruker
Western, Ohio
Do late model F-150 rims have the same bolt hole diameter and back spacing as what used on Rangers?
late model f150 as in what years, and a f150 is a fullsize truck so that = bigger bolt pattern. rangers and broncos have the same lug pattern as a mustangs etc...
F y i :
Late model F150's (04up) are 6 bolt, 04 Heritage Edition & 03 back are 5 on 5.5, while Ranger/Explorer/Bronco II are 5 on 4.5........
97-03 are not 5x5.5 but 5x135mm, which is about 4mm different.
Also, I don't know about the newer ones, but the 97-03 are hub centeric. They use the center of the hub to locate the wheel instead of the lug nut, and the wheel is flat where the lugnuts are instead of countersunk like a "normal" wheel.
