F-150 5.0L Accessory Brackets
spock1996
Minnesota
For anyone running F-150 power steering brackets on a 5.0L.. The power steering pump fluid return port may interfere with the steering box. I was doing some work on my 99 superduty powerstroke today and noticed that the pump looks the same as the one I was planning on using on my ranger but the superduty powerstroke has hydroboost brake booster so it has an extra fluid return port up on the fill neck. It should be possible to use this pump and plug the bottom return that may have interference and use the top return port.:icon_thumby:
I had to do away with the bracket, period.
The stud that sticks out of the steering box was hitting the bottom of my pump.
So, I have to hunt for one off of a mustang.
i made my own engine mounts that work with f150 mounts to set it high enough
Ah...........................I see.
Everything else fits perfectly, except for that stupid pump.............:annoyed::annoyed:
there could be a pump with a remote resvore that would work
where does the bolt hit? Here is one with kinda a external resivor.
This one is for a 84-87 tempo with ac 2.3L Part # E63Z 3A674 AX
has the fluid reture pointing back.
i run the l and l engine mounts in my b2 and it clears just fine(91 f150 accessories):headbang:
