Extended radius arms?
michowski
I just ordered a rough country 4" suspension lift. I was also gonna order some extended radius arms as well. I dont wanna spend 600+ for the skyjacker one and found that tuff country has a set for $430. http://cgi.ebay.com/ebaymotors/83-9...QsspagenameZWD1VQQtrksidZp1638Q2em118Q2el1247 I noticed that with the stock setup of how the radius arms mount that the bracket attatches from the side of the frame and also from underneath. When I saw these brackets it looks like its made for a box frame and just slides on over the frame but the ranger frame isnt boxed. I dont really understand how these brackets mount onto my truck. Do they use the factory holes as well?
Fixed your link (you had "HTTP" in there twice)
I think how they mount is with two bolts on the outside of the frame, and two bolts underneath.
Verify those are infact RANGER Radius arms he's selling, the pic shown on that page is of the F-150 arms.
Will those be setup already for 4 inch lifts? The lift comes with radius arm drop brackets but how will those arms work? Would I have to use the drop brackets from my lift with these new arms or is it bolt on the new arms with there bracket and go?
The arms are designed for a 4" lift, yes.
You remove the factory radius arm crossmember (and any drop brackets), then mount the brackets for the ext. arms further back on the frame.
