Extended Radius Arms v Drop Brackets
How far did you extend your rad. arms? if they are back by your trans cross member you do not need to have a drop bracket
I haven't done it yet- mapping out the lift and just got to thinking about whether I could angle the extended arms to correct the camber as needed to compensate. I've been doing a lot of reading and as you said, extended properly, the drop brackets aren't required.
