extended radius arms or not
bmxnick7
i am going to buy a 6in lift from skyjackeer, my question is should i get extended radius arms or not, leafs or no leafs, dont do much off roading, it is also a 94 2wd 4.0supercab, so i also believe i will need a 1 piece drivew shsft, are they a direct bo;t on
definately leafs. say no to lift blocks. since your going with 6" of suspension lift, ditch the 3" body lift. 2wd, 9"of lift and "not much off roading" is silly.
yes i would get leafs and get the radius arms,i have a 6 inch on my 88 super cab 4x4 and i dont have extended radius arms and i wish i did ,if you got the money then ya do it.you will like the ride and performonce of it.
do i need a one piece drive shaft
yes i will put a one piece in it
