does anyone know if there is a difference between 2wd and 4wd extended radius arms? If so what is the difference? I'm only asking cause I have a set from a 4wd and wanted to use them on my 2wd.
^^^ Agreed, IIRC there is a slight difference in the thickness of the beams, so that the 2x4 rad arm won't fit over the 4x4 beam. I think the length is the same though. I'm wondering if you could go the other way [ 4x4 rad arm on 2x4 beam ] by adding a shim [washer or two]?
Richard
